Disables the automatic clearing of rule usage statistics.
| autoclear | Designates setting parameters for auto-clearing the policy rule usage statistics. |
| interval | Designates disabling automatic clearing of rule usage statistics. |
N/A.
If you have configured Syslog and/or trap actions to notify you when a policy rule is used by using the following command: configure policy rule profile_index [{app-signature group group name name} | ether ether | icmp6type icmp6type | icmptype icmptype | ip6dest ip6dest |ipdestsocket ipdestsocket | ipfrag | ipproto ipproto | ipsourcesocket ipsourcesocket | iptos iptos | ipttl ipttl | macdest macdest | macsource macsource | port port | tcpdestportIP tcpdestportIP | tcpsourceportIP tcpsourceportIP | udpdestportIP udpdestportIP | udpsourceportIP udpsourceportIP ] {mask mask } {port-string [ port_string | all]} {storage-type [non-volatile | volatile]} {drop | forward} {syslog syslog} {trap trap} {cos cos } {mirror-destination control_index} {clear-mirror} , this command disables automatic clearing of rule usage statistics.
To view the auto-clear interval, use the following command:
show policy autoclear interval
The following example disables automatic clearing of rule usage statistics:
# unconfigure policy autoclear interval # show policy autoclear interval Stats autoclear interval DISABLED.
This command was first available in ExtremeXOS 30.2.
